Would it be possible to extend the filter options with a contains option?
I would like to create a filter based on the Long Service Output which contains a word/expression.
I created a check which outputs the available updates on a Windows server and I would like to be able to do a search on all systems which have a certain update available.
For example:
Number of available updates: 2
2020-04 Cumulative Update for Windows Server 2016 for x64-based Systems (KB4550929)
2020-04 Servicing Stack Update for Windows Server 2016 for x64-based Systems (KB4550994)
And now I would like to do a search on: KB4550929 in all service checks.
Thank you…
Best regards,
Rob Hassing
