I have here a new installed server:
# lsb_release -rd
Description: Debian GNU/Linux 10 (buster)
Release: 10
with
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.3-1)
and
# php --version
PHP 7.3.27-1~deb10u1 (cli) (built: Feb 13 2021 16:31:40) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.27, Copyright (c) 1998-2018 Zend Technologies
with Zend OPcache v7.3.27-1~deb10u1, Copyright (c) 1999-2018, by Zend Technologies
After the install of icingaweb2 with
# apt install -y icingaweb2 icingacli
I only see on the webbrowser at "https://monitor.example.tld/icingaweb2/setup
Warning: Uncaught ErrorException: require_once(Zend/Loader/Autoloader.php): failed to open stream: No such file or directory in /usr/share/php/Icinga/Application/ClassLoader.php:273 Stack trace: #0 /usr/share/php/Icinga/Application/ClassLoader.php(273): Icinga\Application\ApplicationBootstrap->Icinga\Application{closure}(2, ârequire_once(ZeâŚâ, â/usr/share/php/âŚâ, 273, Array) #1 /usr/share/php/Icinga/Application/ClassLoader.php(273): require_once() #2 /usr/share/php/Icinga/Application/ClassLoader.php(291): Icinga\Application\ClassLoader->requireZendAutoloader() #3 [internal function]: Icinga\Application\ClassLoader->loadClass(âZend_ControllerâŚâ) #4 /usr/share/php/Icinga/Web/Request.php(14): spl_autoload_call(âZend_ControllerâŚâ) #5 /usr/share/php/Icinga/Application/ClassLoader.php(303): require(â/usr/share/php/âŚâ) #6 [internal function]: Icinga\Application\ClassLoader->loadClass(âIcinga\Web\RequâŚâ) #7 /usr/share/php/Icinga/Application/EmbeddedWeb.php(85): spl_autoload_call(âIcinga\Web\RequâŚâ) #8 /usr/ in /usr/share/php/Icinga/Application/ClassLoader.php on line 273
Fatal error: Icinga\Application\ClassLoader::requireZendAutoloader(): Failed opening required âZend/Loader/Autoloader.phpâ (include_path=â/usr/share/icingaweb2/library/vendor:.:/usr/share/phpâ) in /usr/share/php/Icinga/Application/ClassLoader.php on line 273
Do you have explanations for this and way of solution?
Best regards
Andy
