I’m installing Icinga2 with Icinga Web2 from using the Icinga2/Icinga Web 2 repository, and also I’ve installed/configured the Director from GIT repository on a Red Hat 7.6 prior to executing the web setup.
But the web setup is failing with the following error:
Sorry! Failed to set up Icinga Web 2 successfully.
Successfully connected to existing database “icingaweb2_db”…
Database schema already exists…
Login “icingaweb2” already exists…
Required privileges were already granted to login “icingaweb2”.
The database has been fully set up!General configuration has been successfully written to: /etc/icingaweb2/config.ini
Authentication configuration has been successfully written to: /etc/icingaweb2/authentication.ini
Account “icinga_admin” has been successfully defined as initial administrator.User Group Backend configuration has been successfully written to: /etc/icingaweb2/groups.ini
Resource configuration has been successfully written to: /etc/icingaweb2/resources.ini
Monitoring backend configuration has been successfully written to: /etc/icingaweb2/modules/monitoring/backends.ini
Resource configuration has been successfully updated: /etc/icingaweb2/resources.iniCommand transport configuration has been successfully created: /etc/icingaweb2/modules/monitoring/commandtransports.ini
Monitoring security configuration has been successfully created: /etc/icingaweb2/modules/monitoring/config.ini
Module “director” could not be enabled. An error occured:
ERROR: Icinga\Exception\SystemPermissionException in /usr/share/php/Icinga/Application/Modules/Manager.php:275 with message: Cannot enable module “director”. Check the permissions for the enabledModules directory: /etc/icingaweb2/enabledModules
Module “doc” could not be enabled. An error occured:
ERROR: Icinga\Exception\SystemPermissionException in /usr/share/php/Icinga/Application/Modules/Manager.php:275 with message: Cannot enable module “doc”. Check the permissions for the enabledModules directory: /etc/icingaweb2/enabledModules
Module “monitoring” could not be enabled. An error occured:
ERROR: Icinga\Exception\SystemPermissionException in /usr/share/php/Icinga/Application/Modules/Manager.php:275 with message: Cannot enable module “monitoring”. Check the permissions for the enabledModules directory: /etc/icingaweb2/enabledModules
Here is some info about the version I 've installed:
[root@icinga2 ~]# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.5-1)Copyright (c) 2012-2019 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
There is NO WARRANTY, to the extent permitted by law.System information:
Platform: Red Hat Enterprise Linux Server
Platform version: 7.6 (Maipo)
Kernel: Linux
Kernel version: 3.10.0-957.el7.x86_64
Architecture: x86_64Build information:
Compiler: GNU 4.8.5
Build host: afcad697467eApplication information:
General paths:
Run directory: /run/icinga2Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /varInternal paths:
[root@icinga2 ~]#
