I just spun up a fresh icingaweb2(via docker-compose). I’m able to log in. Is there any documentation on how to add hosts and services to this
Thanks for trying out Icinga and welcome to the community.
There’s a bunch of documentation linked on https://icinga.com/docs/. For example, the Monitoring Basics chapter of the Icinga 2 documentation describes how to configure Icinga 2 to monitor hosts and services. If you prefer a web UI for configuration, take a look at the Icinga Director.
A somewhat guided tour is also available in the Get started guide.
And to point you into the right direction:
For configuration via webinterface → Icinga Director
For configuration via Config Files → Icinga2 Docs / IcingaDSL
It doesn’t hurt to read Icinga2 Docs but not all concepts work in Icinga director.
