We are having a bunch of satellite at some “client” location. We are using “watchdog” to reboot them in case of hard failure… BUT…
Is there a way in icinga to execute a reboot by itself on the satellite if one check failed for 5 mins ?
HI,
it is a little bit difficult that if the icinga daemon dies on the satellite the master can trigger to reboot. You wrote you already tested the watchdog function. I think you mean e.g. systemctl.
You could do a workarround:
