Example for kubernetes yaml to deploy an agent
Hi, i need to deploy an icinga2 satellite to k8s (got several APIs only acessible from there i need to monitor).
Is there an example yaml to deploy an agent somewhere?
Docker Hub contains a list of vars i’ll probably need, but i also will need to add some certificates as secrets and mount them into the container etc. so en example would be really appreciated.
i got quite a bit farther in the meantime, i’ll share the example when i got it working :wink:
i’m currently stuck trying to get the icinga2 satellite to actuvely connect to the master since i don’t want to make it reachable from outside of k8s.
if i read Distributed Monitoring - Icinga 2 correctly, the endpoint entry for the master needs a host entry for that.
since (at least for now) i’m working without any permanent storage for the container i can’t just edit it and i found no way to set it via env (see Docker Hub).
anyone able to give a hint?
scratch that, i found the issue :smiley:
i’ll test a bit more and at least post an example here, maybe make a pull request for the docs so they got a working example :slight_smile:
Hi fireba11,
I’m a little bit too late for this conversation but I hope you might still read this. Do you have a working example that you can show me? :slight_smile:
I also want to deploy a icinga agent on my local kubernetes cluster to play around with it. I already have a icinga master up and running using a pre-made helmrelease.
Would be great if you could share a working example and maybe give some feedback how it went for you.
Thank you in advance!
Best regards!
