I have a custom service that calls a custom command. This command has multiple arguments that are used based on set_if. One of the arguments is optional but takes an array of values from service variable (e.g. vars.something = [ “something1”,“something2”].
In the command argument, how can I evaluate the contents of $something$ in set_if? I know I could create a new variable and set it to true/false and just evaluate it, but is using a function in set_if possible for this?
Thanks!
