Escape quotes on nrpe arguments
Hi all,
I need to execute the following command as an icinga2 service:
# /usr/lib/nagios/plugins/check_nrpe -H 10.0.0.100 -c check_tasksched -a "filter=enabled eq 1 AND title eq 'PKI-Health'" 'crit=exit_code ne 0' show-all 'detail-syntax= Der Job %(title) hat den Exitode %(exit_code)'
 Der Job PKI-Health hat den Exitode 0|'PKI-Health_exit_code'=0;0;0
As in the service definition here
 apply Service "check_checktask_PKI-Health" {
     import "generic-service"
     display_name = "checktask PKI-Health"
     check_command = "nrpe"
     vars.nrpe_command = "check_tasksched"
     vars.nrpe_arguments = "\"filter=enabled eq 1 AND title eq 'PKI-Health'\" 'crit=exit_code ne 0' show-all 'detail-syntax= Der Job %(title) hat den Exitode %(exit_code)'"
     assign where regex("pki", host.name)
The service fails with
Invalid command line: unrecognised option '"filter=enabled eq 1 AND title eq 'PKI-Health'" 'crit=exit_code ne 0' show-all 'detail-syntax= Der Job %(title) hat den Exitode %(exit_code)''
But its exactly what it has to be. Copy/paste the “unrecognised option” to the shell command passes OK.
How do I have to quote the arguments above in the “vars.nrpe_arguments” variable?
Thank you and best regards
Ralf
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.3-1)
Copyright (c) 2012-2019 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later
System information:
  Platform: Ubuntu
  Platform version: 18.04.2 LTS (Bionic Beaver)
  Kernel: Linux
  Kernel version: 4.15.0-46-generic
  Architecture: x86_64
Build information:
  Compiler: GNU 7.3.0
  Build host: 5746b2511d14
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
Perhaps this one might help.
BTW: Please use formatting tags (see FAQ for details) as it enhances readability.
Hi Wolfgang,
i actually used formatting but a “preview post” function would help me to improve the post. :slight_smile:
Regarding your link that is not my recent problem. The arguments itself are passed.
That behaviour happens when I need to escape quotes on some agruments on the commandline as the check itself needs this syntax on the target.
Kind regards
Ralf
Aditionally I see, that the vars.nrpe_arguments are not correctly shown here.
Here you see it better (found the preview :slight_smile: ):
     check_command = "nrpe_legacy"
Looking at the documentation and the other post it should be something like
     vars.nrpe_arguments = [ "-a \"filter=enabled eq 1 AND title eq 'PKI-Health'\" 'crit=exit_code ne 0' show-all 'detail-syntax= Der Job %(title) hat den Exitcode %(exit_code)'"
Good morning,
thank you for you reply.
According to the command definition in /usr/share/icinga2/include/command-plugins.conf I cannot confirm this:
 object CheckCommand "nrpe" {
        import "ipv4-or-ipv6"
        command = [ PluginDir + "/check_nrpe" ]
        arguments = {
                "-a" = {
                        value = "$nrpe_arguments$"
                        repeat_key = false
                        order = 1
Changing that behaviour would lead to have more than 1000 services to be rewritten on my side.
Regards
Ralf
Any further Ideas? I think this is a common topic since lot of services base on NSCP/NRPE arguments.
How does the executed command line from Icinga itself look like?
Hi Michael,
meanwhile I got it working. I need to use the quoted arguments as comma separated array
 vars.nrpe_arguments = [ "filter=enabled eq 1 AND title eq 'PKI-Health'", "crit=exit_code ne 0", "show-all", "detail-syntax= Der Job %(title) hat den Exitode %(exit_code)" ]
Thanks @all for the hints
Cheers
Ralf
