Error while installing icinga2 on RHEL 8.4
This is my first try to install icinga2 on RHEL (8.4) following Installation - Icinga 2.
Running subscription-manager repos --enable rhel-8-server-optional-rpms fails with this error:
Error: ‘rhel-8-server-optional-rpms’ does not match a valid repository ID. Use “subscription-manager repos --list” to see valid repositories.
Obviously not an icinga2 error. Is this an error in my environment or in the documentation?
Hi !
I guess it fails because you don’t have a valid RHEL subscription.
What does the output of the following Command say:
subscription-manager status
Does it look like this ?
   System Status Details
Overall Status: Unknown
System Purpose Status: Unknown
Then there is no subscription attached.
More information on how to activate a rhel subscription is found here.
Even with a Developer License it is needed to activate the subscription to use the only then available repos.
Regards
David
I have registered the server:
# subscription-manager status
Overall Status: Current
System Purpose Status: Not Specified
And does then the enabling of the server optional repo work with the command ?
You can see if it worked with
sudo subscription-manager repos --list-enabled
Which are active !
Regards
David
Oh, My Bad … i investigated a little bit in the Red Hat forums i’ve blanked out that there was a change in the Red Hat Repo Structure. I think there is no server-optional-rpms anymore.
According to the following Post:
There is still the EPEL Part
dnf install https://dl.fedoraproject.org/pub/epel/epel-release-latest-8.noarch.rpm"
And then the missing stuff might be included in
subscription-manager repos --enable codeready-builder-for-rhel-8-x86_64-rpms
I think this also might be helpful for the Service level and attachment
https://computingforgeeks.com/enable-codeready-builder-repo-on-rhel/#:~:text=CodeReady%20Linux%20Builder%20Repository%20can%20be%20enabled%20on%20RHEL%208,is%20enabled%20for%20this%20system.
Regards
David
Ok, the documentation will then need an update? Will you open an issue? (I could do it as well, however, I’m a RHEL novice)
No Problem, Thanks making that aware to us. i will raise in internal request for a change.
This might be the shortest way to resolve this in the Documentation.
Regards
David
Seems to be already corrected. But isn’t updated in the actual Website.
You could take a look here.
