i’m new on this tool. I have successfully installed and almost configuration is completed but while performing Monitoring IDO resource page im getting the below error. Kindly help me on this. It’s really very urgent.
Validation Log
Connection failed SQLSTATE[HY000] [1044] Access denied for user ‘icinga2@localhost’@’%’ to database ‘icinga2’
“Connection failed SQLSTATE[HY000] [1044] Access denied for user
‘icinga2@localhost’@’%’ to database ‘icinga2’”
tells you that you are trying to connect with username “icinga2@localhost”
and this does not match what you have in your database (I’m pretty certain you
cannot have an @ sign in a username anyway).
So, you do not need to modify the user table of your database - you need to
correct the username which is trying to access that database.
Go back to the configuration steps you have performed and see where you entered
“icinga2@localhost” for a username. That is what needs changing.
Sorry, but I am not your personal assistant - this is a mailing list / forum
with many people who can help out, and many of us also have day jobs (which I
am doing right now).
Please help me on this.
Assistance from everyone here is provided on a “best effort” basis, and you’ve
already had suggestions from both myself and Roland.
You should specifically pay attention to Roland’s correction of the punctuation
in your SQL statement, and let us know what happens after you have applied
that.
Hey @pranavrn - if your topic is resolved, please also make sure to mark the response that helped you solve it as the “solution” by clicking the three dots on that message.
