Error when run "icingacli reporting schedule run"
   icinga2 - The Icinga 2 network monitoring daemon (version: r2.10.4-1)
System information:
Platform: Ubuntu
Platform version: 18.04.2 LTS (Bionic Beaver)
Kernel: Linux
Kernel version: 4.15.0-51-generic
Architecture: x86_64
Build information:
Compiler: GNU 7.3.0
Build host: b2ecadfb68ab
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
ā€œI’m trying to install Reporting module, get the below-mentioned errorā€
ERROR: PDOException in /usr/share/icingaweb2/modules/ipl/vendor/ipl/sql/src/Connection.php:314 with message: SQLSTATE[42S02]: Base table or view not found: 1146 Table ā€˜reporting.schedule’ doesn’t exist
Followed this link for installation ā€œhttps://icinga.com/docs/reporting/latest/ā€
Seems like the schema wasnt imported.
If you log in the database, do you see any tables under the reporting database? If empty, try importing the schema again as in the docs:
mysql -p -u root reporting < schema/mysql.sql
Take notice that the path is relative and you need to actually go to ā€œ/usr/share/icingaweb2/modules/reportingā€ or wherever IcingaWeb is installed.
George
Thanks a lot, My mistake i was referring to this file till ā€œ/usr/share/icinga2-ido-mysql/schema/mysql.sqlā€
Now its working fine.
I can see SLA for overall system.
What if i want to limit this SLA to specific hostgroup ? Let’s say ā€œcritical_serversā€.
Can this be done ?
Thanks for the help, Info was available to achieve on filtering SLA after i made mistake.
Now it’s working smooth for me :slight_smile:
