Error when monitor network traffic with check_eth
I’m a new member of the community, I have a problem with the check_eth script when it runs as a command via SSH.
I created a service on Master Icinga and in the path /usr/lib/nagios/plugins on Host I copied the script check_eth.
If run via terminal on Master the command
/usr/lib/nagios/plugins/check_by_ssh -H 10.1.1.60 -C “/usr/lib/nagios/plugins/check_eth -i ens18 -w 1024K Bps -c 2048K Bps” -l nagios
I receive correctly
RX Bytes: 825MB, TX Bytes: 906MB; RX Speed: 39KBps, TX Speed: 42KBps; OK bandwidth utilization | rx=39815;1048576;2097152 tx=43196;1048576;2097152
If when the command start with icinga the result is
Usage: /usr/lib/nagios/plugins/check_eth -i -w -c [-p -b ]
-i, --interface STRING
Network interface name (example: eth0)
-w, --warning STRING
Warning interface speed level (K/M/G Bps, k/m/g bps)
If using with -p value should be in percentage (1-100)
-c, --critilcal STRING
Critical interface speed level (K/M/G Bps, k/m/g bps)
-p
Calculate warning and critical levels in percentage based on interface bandwidth
-b, --bandwidth STRING
Interface bandwidth value (K/M/G Bps, k/m/g bps)
The service created is:
apply Service “SSH_Net” {
import “by_ssh”
vars.check_command = “Network-Linux”
vars.by_ssh_command = “/usr/lib/nagios/plugins/check_eth”
vars.by_ssh_arguments = {
“-i” = {
value = “ens18”,
order = 0
“-w” = {
value = “1M Bps”,
order = 1
“-c” = {
value = “2M Bps”,
order = 2
Your problem is probably quoting and how arguments are interpreted by the check_eth plugin.
In your first example arguments are like this, every split line is a single argument.
                                  __ _____ __ _____ ___ __ _____ ___
So in your manual example only 1024K is used for -w.
Now your Icinga 2 example uses ssh_arguments, where the value is 1M Bps. This will result in the following command being executed via SSH. Note the quotes making sure that the whitespace is part of the argument value, and not a new argument.
/usr/lib/nagios/plugins/check_eth -i 'ens18' -w '1M Bps' -c '2M Bps'
Note: You can also specify the command line fully to by_ssh_command without arguments.
In fact the problem is the quotation marks, when via terminal console i use the same command passed by Icinga
/usr/lib/nagios/plugins/check_by_ssh -C ‘’/usr/lib/nagios/plugins/check_eth’ ‘-i’ ‘ens18’ ‘-w’ ‘1024K Bps’ ‘-c’ ‘2048K Bps’’ -H 10.1.1.60 -l nagios
the result is the error again
To solve it I had to do as you suggested and I wrote the command line fully to by_ssh_command without arguments.
Thanks so much
Hi frosch, :wink:
i have the same problem with the quotation mark. In my case, i didn’t want use the check_ssh plugin. Is there a way to say icinga2 don’t use quotation marks?
/usr/lib/nagios/plugins/check_eth -i eno1 -w 50m Bps -c 100m bps
RX Bytes: 2GB, TX Bytes: 2GB; RX Speed: 756Bps, TX Speed: 419Bps; OK bandwidth utilization | rx=756;6553600;13107200 tx=419;6553600;13107200
‘/usr/lib/nagios/plugins/check_eth’ ‘-i’ ‘eno1’ ‘-w’ ‘50m bps’ ‘-c’ ‘100 m bps’
-> don’t work
Cheers, Marco
