Hi guys. I’m trying to setup my first Icinga2 installation following the guide step-by-step on:
https://icinga.com/docs/icinga2/latest/doc/02-installation/.
Im installing on CentOS 7 and just went through the step on installing MariaDB and Enabling the ido-MySQL module:
# icinga2 feature enable ido-mysql
Module ‘ido-mysql’ was enabled.
Make sure to restart Icinga 2 for these changes to take effect.
When I restart Icinga2 using systemctl restart icinga2 I get the following error:
Job for icinga2.service failed because the control process exited with error code. See “systemctl status icinga2.service” and “journalctl -xe” for details.
If I disable ido-mySQL I can start icinga2 without issue so seems to be related to MariaDB or the dB?
I’m new to both linux and icinga2 so I’m pretty stuck.
Any help appreciated.
