I have a CentOS7 with IcingaWeb, another Centos7 for database
I have installed php-gmp also.
defined a test for a specific host with a port.
icingacli x509 scan --job test
PHP Fatal error: Trait ‘ipl\Scheduler\Common\TaskProperties’ not found in /usr/share/icingaweb2/modules/x509/library/X509/Common/JobUtils.php on line 15Fatal error: Trait ‘ipl\Scheduler\Common\TaskProperties’ not found in /usr/share/icingaweb2/modules/x509/library/X509/Common/JobUtils.php on line 15
I have a question regarding the requirements:
ipl version available is only 0.10. it’s an unstable version 0.11.0-dev. is this correct? Am I missing something here?
Thanks,
Adrian
