Good morning, the first thing is that it is the first time that I am configuring icinga.
I have mounted icinga correctly, but when I try to mount director, it shows me the following error:
vim /etc/icinga2/zones.conf
Thanks in advance
Thanks in advance
did you set up the api user “director” ?
If in the end that was the problem. Thank you
