I’d like to set an environment variable (LANG=“en_US.UTF-8”) for all check commands in order to handle non ascii characters within with python2 checks.
There is the import “plugin-check-command” statement in all of my custom commands, so I would except it makes sense to put it in there. Unfortunately I cannot find the configuration for plugin-check-command.
Is there a recommended may to set environment variables for all commands?
System Information
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: 2.13.2-1)
Copyright (c) 2012-2022 Icinga GmbH (https://icinga.com/)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Red Hat Enterprise Linux Server
Platform version: 7.9 (Maipo)
Kernel: Linux
Kernel version: 3.10.0-1160.53.1.el7.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.5
Build host: runner-hh8q3bz2-project-322-concurrent-0
OpenSSL version: OpenSSL 1.0.2k-fips 26 Jan 2017
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf icingadb influxdb influxdb2 livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command graphite ido-pgsql mainlog notificatio
Icinga is running as standalone server (no satellites, no agents)
