Enable_ha not available in graphite feature
Hello everyone,
according to the documentation https://icinga.com/docs/icinga2/latest/doc/09-object-types/#graphitewriter (And also according to PR https://github.com/Icinga/icinga2/pull/6725) there should be available enable_ha config in graphite feature, but I cannot run Icinga2 with this line of config. Is there any problem on my side?
Config:
Managed by Puppet
# any manual changes will be OVERWRITTEN
 * The GraphiteWriter type writes check result metrics and
 * performance data to a graphite tcp socket.
object GraphiteWriter "graphite-grafana" {
  host = "10.5.16.28"
  port = 2003
  enable_send_metadata = true
  enable_send_thresholds = false
  enable_ha = true
Error message:
10:02 # icinga2 daemon -C
[2019-06-19 10:04:17 +0200] information/cli: Icinga application loader (version: r2.10.5-1)
[2019-06-19 10:04:17 +0200] information/cli: Loading configuration file(s).
[2019-06-19 10:04:17 +0200] information/ConfigItem: Committing config item(s).
[2019-06-19 10:04:17 +0200] information/ApiListener: My API identity: icinga-master1.it4i.cz
[2019-06-19 10:04:17 +0200] critical/config: Error: Attribute 'enable_ha' does not exist.
Location: in /etc/icinga2/features-enabled/graphite.conf: 16:3-16:18
/etc/icinga2/features-enabled/graphite.conf(14):   enable_send_metadata = true
/etc/icinga2/features-enabled/graphite.conf(15):   enable_send_thresholds = false
/etc/icinga2/features-enabled/graphite.conf(16):   enable_ha = true
/etc/icinga2/features-enabled/graphite.conf(17): }
/etc/icinga2/features-enabled/graphite.conf(18):
[2019-06-19 10:04:17 +0200] critical/config: 1 error
Current GraphiteWriter object:
09:56 # icinga2 object list --type=GraphiteWriter
Object 'graphite-grafana' of type 'GraphiteWriter':
  % declared in '/etc/icinga2/features-enabled/graphite.conf', lines 10:1-10:40
  * __name = "graphite-grafana"
  * enable_send_metadata = true
    % = modified in '/etc/icinga2/features-enabled/graphite.conf', lines 14:3-14:29
  * enable_send_thresholds = false
    % = modified in '/etc/icinga2/features-enabled/graphite.conf', lines 15:3-15:32
  * host = "10.5.16.28"
    % = modified in '/etc/icinga2/features-enabled/graphite.conf', lines 11:3-11:21
  * host_name_template = "icinga2.$host.name$.host.$host.check_command$"
  * name = "graphite-grafana"
  * package = "_etc"
  * port = "2003"
    % = modified in '/etc/icinga2/features-enabled/graphite.conf', lines 12:3-12:13
  * service_name_template = "icinga2.$host.name$.services.$service.name$.$service.check_command$"
  * source_location
    * first_column = 1
    * first_line = 10
    * last_column = 40
    * last_line = 10
    * path = "/etc/icinga2/features-enabled/graphite.conf"
  * templates = [ "graphite-grafana" ]
    % = modified in '/etc/icinga2/features-enabled/graphite.conf', lines 10:1-10:40
  * type = "GraphiteWriter"
  * zone = ""
Icinga version:
09:59 # icinga2 -V
Copyright (c) 2012-2019 Icinga GmbH (https://icinga.com/)
System information:
  Platform: CentOS Linux
  Platform version: 7 (Core)
  Kernel: Linux
  Kernel version: 3.10.0-957.21.2.el7.x86_64
  Architecture: x86_64
Build information:
  Compiler: GNU 4.8.5
  Build host: afcad697467e
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
Thank you in advance for any help.
Lukas
thanks for the finding, this shouldn’t have been backported to 2.10. This feature is solely available and implemented with the coming 2.11 release.
Fixed the docs.
OK, well than documentation refers to something which is not yet available. Shouldn’t it be hidden for time being?
When is 2.11 coming to production anyway?
Regards,
Lukas
I’ve already fixed it and re-run the online docs generator.
2.11 has some issues left open being worked on. Once there is an estimate, a date will be scheduled. Highly likely there will be a release candidate first due to the network stack changes.
You can follow the progress here.
