Hi Community,
im very new to the elastic stuff and wanted to test it.
I installed a new elastic 7.0.0 Test enviroment and tried to use the icingabeat.
I think the json template is not compatible because in the tDebug log of icingbeat I got the following
2019-04-18T14:34:12.038+0200 DEBUG [icingabeat.eventstream] beater/eventstream.go:151 Event sent
2019-04-18T14:34:13.523+0200 ERROR pipeline/output.go:100 Failed to connect to backoff(elasticsearch(http://XX.XX.XX.XX:9200)): Connection marked as failed because the onConnect callback failed: Error loading Elasticsearch template: could not load template. Elasticsearch returned: couldn’t load template: couldn’t load json. Error: 400 Bad Request: {“error”:{“root_cause”:[{“type”:“mapper_parsing_exception”,“reason”:“Root mapping definition has unsupported parameters: [doc : {_meta={version=6.5.4}, dynamic_templates=[{fields={path_match=fields., mapping={type=keyword}, match_mapping_type=string}}, {docker.container.labels={path_match=docker.container.labels., mapping={type=keyword}, match_mapping_type=string}}, {strings_as_keyword={mapping={ignore_above=1024, type=keyword}, match_mapping_type=string}}], date_detection=false, properties={kubernetes={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, node={properties={name={ignore_above=1024, type=keyword}}}, pod={properties={uid={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, namespace={ignore_above=1024, type=keyword}, annotations={type=object}, labels={type=object}}}, @timestamp={type=date}, meta={properties={cloud={properties={machine_type={ignore_above=1024, type=keyword}, availability_zone={ignore_above=1024, type=keyword}, instance_id={ignore_above=1024, type=keyword}, instance_name={ignore_above=1024, type=keyword}, project_id={ignore_above=1024, type=keyword}, provider={ignore_above=1024, type=keyword}, region={ignore_above=1024, type=keyword}}}}}, host={properties={os={properties={family={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, platform={ignore_above=1024, type=keyword}}}, ip={type=ip}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, mac={ignore_above=1024, type=keyword}, architecture={ignore_above=1024, type=keyword}}}, icinga={properties={notification_type={ignore_above=1024, type=keyword}, acknowledgement_type={type=long}, author={ignore_above=1024, type=keyword}, state_type={type=long}, type={ignore_above=1024, type=keyword}, users={ignore_above=1024, type=keyword}, notify={ignore_above=1024, type=keyword}, downtime={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, scheduled_by={norms=false, type=text}, was_cancelled={type=boolean}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, end_time={type=date}, config_owner={norms=false, type=text}, triggers={norms=false, type=text}, triggered_by={norms=false, type=text}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, duration={type=long}, start_time={type=date}, trigger_time={type=date}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, fixed={type=boolean}, comment={norms=false, type=text}, host_name={ignore_above=1024, type=keyword}}}, check_result={properties={performance_data={norms=false, type=text}, active={type=boolean}, type={ignore_above=1024, type=keyword}, exit_status={type=long}, ttl={type=long}, command={norms=false, type=text}, execution_end={type=date}, output={norms=false, type=text}, vars_after={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, check_source={ignore_above=1024, type=keyword}, schedule_end={type=date}, execution_start={type=date}, state={type=long}, vars_before={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, schedule_start={type=date}}}, service={ignore_above=1024, type=keyword}, host={ignore_above=1024, type=keyword}, comment={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, expire_time={type=date}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, text={norms=false, type=text}, entry_type={type=long}, host_name={ignore_above=1024, type=keyword}}}, state={type=long}, expiry={type=date}, text={norms=false, type=text}, timestamp={type=date}, status={properties={num_hosts_up={type=long}, avg_latency={type=long}, passive_service_checks_15min={type=long}, num_hosts_in_downtime={type=long}, num_services_acknowledged={type=long}, passive_host_checks={type=long}, filelogger={properties={main-log={type=long}}}, active_service_checks_1min={type=long}, passive_host_checks_15min={type=long}, num_services_in_downtime={type=long}, passive_service_checks={type=long}, num_hosts_unreachable={type=long}, num_services_flapping={type=long}, active_service_checks_15min={type=long}, api={properties={num_conn_endpoints={type=long}, identity={ignore_above=1024, type=keyword}, num_not_conn_endpoints={type=long}, num_endpoints={type=long}}}, active_host_checks_1min={type=long}, icingaapplication={properties={app={properties={enable_notifications={type=boolean}, enable_event_handlers={type=boolean}, enable_perfdata={type=boolean}, node_name={ignore_above=1024, type=keyword}, program_start={type=long}, pid={type=long}, enable_host_checks={type=boolean}, version={ignore_above=1024, type=keyword}, enable_service_checks={type=boolean}, enable_flapping={type=boolean}}}}}, num_services_ok={type=long}, active_host_checks={type=long}, checkercomponent={properties={checker={properties={idle={type=long}, pending={type=long}}}}}, min_execution_time={type=long}, active_host_checks_5min={type=long}, min_latency={type=long}, active_host_checks_15min={type=long}, num_hosts_flapping={type=long}, active_service_checks={type=long}, num_services_unknown={type=long}, notificationcomponent={properties={notification={type=long}}}, passive_service_checks_1min={type=long}, passive_host_checks_1min={type=long}, num_services_unreachable={type=long}, avg_execution_time={type=long}, passive_host_checks_5min={type=long}, max_execution_time={type=long}, active_service_checks_5min={type=long}, num_hosts_pending={type=long}, uptime={type=long}, max_latency={type=long}, num_services_critical={type=long}, passive_service_checks_5min={type=long}, num_hosts_acknowledged={type=long}, idomysqlconnection={properties={ido-mysql={properties={connected={type=boolean}, instance_name={ignore_above=1024, type=keyword}, query_queue_items={type=long}, version={ignore_above=1024, type=keyword}}}}}, num_services_pending={type=long}, num_hosts_down={type=long}, num_services_warning={type=long}}}}}, beat={properties={hostname={ignore_above=1024, type=keyword}, timezone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}}}, type={ignore_above=1024, type=keyword}, fields={type=object}, error={properties={code={type=long}, message={norms=false, type=text}, type={ignore_above=1024, type=keyword}}}, tags={ignore_above=1024, type=keyword}, docker={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, labels={type=object}}}}}, timestamp={type=date}}}]”}],“type”:“mapper_parsing_exception”,“reason”:“Failed to parse mapping [_doc]: Root mapping definition has unsupported parameters: [doc : {_meta={version=6.5.4}, dynamic_templates=[{fields={path_match=fields., mapping={type=keyword}, match_mapping_type=string}}, {docker.container.labels={path_match=docker.container.labels., mapping={type=keyword}, match_mapping_type=string}}, {strings_as_keyword={mapping={ignore_above=1024, type=keyword}, match_mapping_type=string}}], date_detection=false, properties={kubernetes={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, node={properties={name={ignore_above=1024, type=keyword}}}, pod={properties={uid={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, namespace={ignore_above=1024, type=keyword}, annotations={type=object}, labels={type=object}}}, @timestamp={type=date}, meta={properties={cloud={properties={machine_type={ignore_above=1024, type=keyword}, availability_zone={ignore_above=1024, type=keyword}, instance_id={ignore_above=1024, type=keyword}, instance_name={ignore_above=1024, type=keyword}, project_id={ignore_above=1024, type=keyword}, provider={ignore_above=1024, type=keyword}, region={ignore_above=1024, type=keyword}}}}}, host={properties={os={properties={family={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, platform={ignore_above=1024, type=keyword}}}, ip={type=ip}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, mac={ignore_above=1024, type=keyword}, architecture={ignore_above=1024, type=keyword}}}, icinga={properties={notification_type={ignore_above=1024, type=keyword}, acknowledgement_type={type=long}, author={ignore_above=1024, type=keyword}, state_type={type=long}, type={ignore_above=1024, type=keyword}, users={ignore_above=1024, type=keyword}, notify={ignore_above=1024, type=keyword}, downtime={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, scheduled_by={norms=false, type=text}, was_cancelled={type=boolean}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, end_time={type=date}, config_owner={norms=false, type=text}, triggers={norms=false, type=text}, triggered_by={norms=false, type=text}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, duration={type=long}, start_time={type=date}, trigger_time={type=date}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, fixed={type=boolean}, comment={norms=false, type=text}, host_name={ignore_above=1024, type=keyword}}}, check_result={properties={performance_data={norms=false, type=text}, active={type=boolean}, type={ignore_above=1024, type=keyword}, exit_status={type=long}, ttl={type=long}, command={norms=false, type=text}, execution_end={type=date}, output={norms=false, type=text}, vars_after={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, check_source={ignore_above=1024, type=keyword}, schedule_end={type=date}, execution_start={type=date}, state={type=long}, vars_before={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, schedule_start={type=date}}}, service={ignore_above=1024, type=keyword}, host={ignore_above=1024, type=keyword}, comment={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, expire_time={type=date}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, text={norms=false, type=text}, entry_type={type=long}, host_name={ignore_above=1024, type=keyword}}}, state={type=long}, expiry={type=date}, text={norms=false, type=text}, timestamp={type=date}, status={properties={num_hosts_up={type=long}, avg_latency={type=long}, passive_service_checks_15min={type=long}, num_hosts_in_downtime={type=long}, num_services_acknowledged={type=long}, passive_host_checks={type=long}, filelogger={properties={main-log={type=long}}}, active_service_checks_1min={type=long}, passive_host_checks_15min={type=long}, num_services_in_downtime={type=long}, passive_service_checks={type=long}, num_hosts_unreachable={type=long}, num_services_flapping={type=long}, active_service_checks_15min={type=long}, api={properties={num_conn_endpoints={type=long}, identity={ignore_above=1024, type=keyword}, num_not_conn_endpoints={type=long}, num_endpoints={type=long}}}, active_host_checks_1min={type=long}, icingaapplication={properties={app={properties={enable_notifications={type=boolean}, enable_event_handlers={type=boolean}, enable_perfdata={type=boolean}, node_name={ignore_above=1024, type=keyword}, program_start={type=long}, pid={type=long}, enable_host_checks={type=boolean}, version={ignore_above=1024, type=keyword}, enable_service_checks={type=boolean}, enable_flapping={type=boolean}}}}}, num_services_ok={type=long}, active_host_checks={type=long}, checkercomponent={properties={checker={properties={idle={type=long}, pending={type=long}}}}}, min_execution_time={type=long}, active_host_checks_5min={type=long}, min_latency={type=long}, active_host_checks_15min={type=long}, num_hosts_flapping={type=long}, active_service_checks={type=long}, num_services_unknown={type=long}, notificationcomponent={properties={notification={type=long}}}, passive_service_checks_1min={type=long}, passive_host_checks_1min={type=long}, num_services_unreachable={type=long}, avg_execution_time={type=long}, passive_host_checks_5min={type=long}, max_execution_time={type=long}, active_service_checks_5min={type=long}, num_hosts_pending={type=long}, uptime={type=long}, max_latency={type=long}, num_services_critical={type=long}, passive_service_checks_5min={type=long}, num_hosts_acknowledged={type=long}, idomysqlconnection={properties={ido-mysql={properties={connected={type=boolean}, instance_name={ignore_above=1024, type=keyword}, query_queue_items={type=long}, version={ignore_above=1024, type=keyword}}}}}, num_services_pending={type=long}, num_hosts_down={type=long}, num_services_warning={type=long}}}}}, beat={properties={hostname={ignore_above=1024, type=keyword}, timezone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}}}, type={ignore_above=1024, type=keyword}, fields={type=object}, error={properties={code={type=long}, message={norms=false, type=text}, type={ignore_above=1024, type=keyword}}}, tags={ignore_above=1024, type=keyword}, docker={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, labels={type=object}}}}}, timestamp={type=date}}}]”,“caused_by”:{“type”:“mapper_parsing_exception”,“reason”:“Root mapping definition has unsupported parameters: [doc : {_meta={version=6.5.4}, dynamic_templates=[{fields={path_match=fields., mapping={type=keyword}, match_mapping_type=string}}, {docker.container.labels={path_match=docker.container.labels., mapping={type=keyword}, match_mapping_type=string}}, {strings_as_keyword={mapping={ignore_above=1024, type=keyword}, match_mapping_type=string}}], date_detection=false, properties={kubernetes={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, node={properties={name={ignore_above=1024, type=keyword}}}, pod={properties={uid={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, namespace={ignore_above=1024, type=keyword}, annotations={type=object}, labels={type=object}}}, @timestamp={type=date}, meta={properties={cloud={properties={machine_type={ignore_above=1024, type=keyword}, availability_zone={ignore_above=1024, type=keyword}, instance_id={ignore_above=1024, type=keyword}, instance_name={ignore_above=1024, type=keyword}, project_id={ignore_above=1024, type=keyword}, provider={ignore_above=1024, type=keyword}, region={ignore_above=1024, type=keyword}}}}}, host={properties={os={properties={family={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, platform={ignore_above=1024, type=keyword}}}, ip={type=ip}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, mac={ignore_above=1024, type=keyword}, architecture={ignore_above=1024, type=keyword}}}, icinga={properties={notification_type={ignore_above=1024, type=keyword}, acknowledgement_type={type=long}, author={ignore_above=1024, type=keyword}, state_type={type=long}, type={ignore_above=1024, type=keyword}, users={ignore_above=1024, type=keyword}, notify={ignore_above=1024, type=keyword}, downtime={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, scheduled_by={norms=false, type=text}, was_cancelled={type=boolean}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, end_time={type=date}, config_owner={norms=false, type=text}, triggers={norms=false, type=text}, triggered_by={norms=false, type=text}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, duration={type=long}, start_time={type=date}, trigger_time={type=date}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, fixed={type=boolean}, comment={norms=false, type=text}, host_name={ignore_above=1024, type=keyword}}}, check_result={properties={performance_data={norms=false, type=text}, active={type=boolean}, type={ignore_above=1024, type=keyword}, exit_status={type=long}, ttl={type=long}, command={norms=false, type=text}, execution_end={type=date}, output={norms=false, type=text}, vars_after={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, check_source={ignore_above=1024, type=keyword}, schedule_end={type=date}, execution_start={type=date}, state={type=long}, vars_before={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, schedule_start={type=date}}}, service={ignore_above=1024, type=keyword}, host={ignore_above=1024, type=keyword}, comment={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, expire_time={type=date}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, text={norms=false, type=text}, entry_type={type=long}, host_name={ignore_above=1024, type=keyword}}}, state={type=long}, expiry={type=date}, text={norms=false, type=text}, timestamp={type=date}, status={properties={num_hosts_up={type=long}, avg_latency={type=long}, passive_service_checks_15min={type=long}, num_hosts_in_downtime={type=long}, num_services_acknowledged={type=long}, passive_host_checks={type=long}, filelogger={properties={main-log={type=long}}}, active_service_checks_1min={type=long}, passive_host_checks_15min={type=long}, num_services_in_downtime={type=long}, passive_service_checks={type=long}, num_hosts_unreachable={type=long}, num_services_flapping={type=long}, active_service_checks_15min={type=long}, api={properties={num_conn_endpoints={type=long}, identity={ignore_above=1024, type=keyword}, num_not_conn_endpoints={type=long}, num_endpoints={type=long}}}, active_host_checks_1min={type=long}, icingaapplication={properties={app={properties={enable_notifications={type=boolean}, enable_event_handlers={type=boolean}, enable_perfdata={type=boolean}, node_name={ignore_above=1024, type=keyword}, program_start={type=long}, pid={type=long}, enable_host_checks={type=boolean}, version={ignore_above=1024, type=keyword}, enable_service_checks={type=boolean}, enable_flapping={type=boolean}}}}}, num_services_ok={type=long}, active_host_checks={type=long}, checkercomponent={properties={checker={properties={idle={type=long}, pending={type=long}}}}}, min_execution_time={type=long}, active_host_checks_5min={type=long}, min_latency={type=long}, active_host_checks_15min={type=long}, num_hosts_flapping={type=long}, active_service_checks={type=long}, num_services_unknown={type=long}, notificationcomponent={properties={notification={type=long}}}, passive_service_checks_1min={type=long}, passive_host_checks_1min={type=long}, num_services_unreachable={type=long}, avg_execution_time={type=long}, passive_host_checks_5min={type=long}, max_execution_time={type=long}, active_service_checks_5min={type=long}, num_hosts_pending={type=long}, uptime={type=long}, max_latency={type=long}, num_services_critical={type=long}, passive_service_checks_5min={type=long}, num_hosts_acknowledged={type=long}, idomysqlconnection={properties={ido-mysql={properties={connected={type=boolean}, instance_name={ignore_above=1024, type=keyword}, query_queue_items={type=long}, version={ignore_above=1024, type=keyword}}}}}, num_services_pending={type=long}, num_hosts_down={type=long}, num_services_warning={type=long}}}}}, beat={properties={hostname={ignore_above=1024, type=keyword}, timezone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}}}, type={ignore_above=1024, type=keyword}, fields={type=object}, error={properties={code={type=long}, message={norms=false, type=text}, type={ignore_above=1024, type=keyword}}}, tags={ignore_above=1024, type=keyword}, docker={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, labels={type=object}}}}}, timestamp={type=date}}}]”}},“status”:400}. Response body: {“error”:{“root_cause”:[{“type”:“mapper_parsing_exception”,“reason”:“Root mapping definition has unsupported parameters: [doc : {_meta={version=6.5.4}, dynamic_templates=[{fields={path_match=fields., mapping={type=keyword}, match_mapping_type=string}}, {docker.container.labels={path_match=docker.container.labels., mapping={type=keyword}, match_mapping_type=string}}, {strings_as_keyword={mapping={ignore_above=1024, type=keyword}, match_mapping_type=string}}], date_detection=false, properties={kubernetes={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, node={properties={name={ignore_above=1024, type=keyword}}}, pod={properties={uid={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, namespace={ignore_above=1024, type=keyword}, annotations={type=object}, labels={type=object}}}, @timestamp={type=date}, meta={properties={cloud={properties={machine_type={ignore_above=1024, type=keyword}, availability_zone={ignore_above=1024, type=keyword}, instance_id={ignore_above=1024, type=keyword}, instance_name={ignore_above=1024, type=keyword}, project_id={ignore_above=1024, type=keyword}, provider={ignore_above=1024, type=keyword}, region={ignore_above=1024, type=keyword}}}}}, host={properties={os={properties={family={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, platform={ignore_above=1024, type=keyword}}}, ip={type=ip}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, mac={ignore_above=1024, type=keyword}, architecture={ignore_above=1024, type=keyword}}}, icinga={properties={notification_type={ignore_above=1024, type=keyword}, acknowledgement_type={type=long}, author={ignore_above=1024, type=keyword}, state_type={type=long}, type={ignore_above=1024, type=keyword}, users={ignore_above=1024, type=keyword}, notify={ignore_above=1024, type=keyword}, downtime={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, scheduled_by={norms=false, type=text}, was_cancelled={type=boolean}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, end_time={type=date}, config_owner={norms=false, type=text}, triggers={norms=false, type=text}, triggered_by={norms=false, type=text}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, duration={type=long}, start_time={type=date}, trigger_time={type=date}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, fixed={type=boolean}, comment={norms=false, type=text}, host_name={ignore_above=1024, type=keyword}}}, check_result={properties={performance_data={norms=false, type=text}, active={type=boolean}, type={ignore_above=1024, type=keyword}, exit_status={type=long}, ttl={type=long}, command={norms=false, type=text}, execution_end={type=date}, output={norms=false, type=text}, vars_after={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, check_source={ignore_above=1024, type=keyword}, schedule_end={type=date}, execution_start={type=date}, state={type=long}, vars_before={properties={state_type={type=long}, state={type=long}, attempt={type=long}, reachable={type=boolean}}}, schedule_start={type=date}}}, service={ignore_above=1024, type=keyword}, host={ignore_above=1024, type=keyword}, comment={properties={entry_time={type=date}, __name={norms=false, type=text}, package={ignore_above=1024, type=keyword}, author={ignore_above=1024, type=keyword}, service_name={ignore_above=1024, type=keyword}, templates={norms=false, type=text}, expire_time={type=date}, type={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}, zone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, legacy_id={type=long}, text={norms=false, type=text}, entry_type={type=long}, host_name={ignore_above=1024, type=keyword}}}, state={type=long}, expiry={type=date}, text={norms=false, type=text}, timestamp={type=date}, status={properties={num_hosts_up={type=long}, avg_latency={type=long}, passive_service_checks_15min={type=long}, num_hosts_in_downtime={type=long}, num_services_acknowledged={type=long}, passive_host_checks={type=long}, filelogger={properties={main-log={type=long}}}, active_service_checks_1min={type=long}, passive_host_checks_15min={type=long}, num_services_in_downtime={type=long}, passive_service_checks={type=long}, num_hosts_unreachable={type=long}, num_services_flapping={type=long}, active_service_checks_15min={type=long}, api={properties={num_conn_endpoints={type=long}, identity={ignore_above=1024, type=keyword}, num_not_conn_endpoints={type=long}, num_endpoints={type=long}}}, active_host_checks_1min={type=long}, icingaapplication={properties={app={properties={enable_notifications={type=boolean}, enable_event_handlers={type=boolean}, enable_perfdata={type=boolean}, node_name={ignore_above=1024, type=keyword}, program_start={type=long}, pid={type=long}, enable_host_checks={type=boolean}, version={ignore_above=1024, type=keyword}, enable_service_checks={type=boolean}, enable_flapping={type=boolean}}}}}, num_services_ok={type=long}, active_host_checks={type=long}, checkercomponent={properties={checker={properties={idle={type=long}, pending={type=long}}}}}, min_execution_time={type=long}, active_host_checks_5min={type=long}, min_latency={type=long}, active_host_checks_15min={type=long}, num_hosts_flapping={type=long}, active_service_checks={type=long}, num_services_unknown={type=long}, notificationcomponent={properties={notification={type=long}}}, passive_service_checks_1min={type=long}, passive_host_checks_1min={type=long}, num_services_unreachable={type=long}, avg_execution_time={type=long}, passive_host_checks_5min={type=long}, max_execution_time={type=long}, active_service_checks_5min={type=long}, num_hosts_pending={type=long}, uptime={type=long}, max_latency={type=long}, num_services_critical={type=long}, passive_service_checks_5min={type=long}, num_hosts_acknowledged={type=long}, idomysqlconnection={properties={ido-mysql={properties={connected={type=boolean}, instance_name={ignore_above=1024, type=keyword}, query_queue_items={type=long}, version={ignore_above=1024, type=keyword}}}}}, num_services_pending={type=long}, num_hosts_down={type=long}, num_services_warning={type=long}}}}}, beat={properties={hostname={ignore_above=1024, type=keyword}, timezone={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, version={ignore_above=1024, type=keyword}}}, type={ignore_above=1024, type=keyword}, fields={type=object}, error={properties={code={type=long}, message={norms=false, type=text}, type={ignore_above=1024, type=keyword}}}, tags={ignore_above=1024, type=keyword}, docker={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}, id={ignore_above=1024, type=keyword}, labels={type=object}}}}}, timestamp={type=date}}}]”}],“type”:“mapper_parsing_exception”,“reason”:"Failed to parse mapping [_doc]: Root mapping definition has unsupported parameters: [doc : {_meta={version=6.5.4}, dynamic_templates=[{fields={path_match=fields., mapping={type=keyword}, match_mapping_type=string}}, {docker.container.labels={path_match=docker.container.labels., mapping={type=keyword}, match_mapping_type=string}}, {strings_as_keyword={mapping={ignore_above=1024, type=keyword}, match_mapping_type=string}}], date_detection=false, properties={kubernetes={properties={container={properties={image={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, node={properties={name={ignore_above=1024, type=keyword}}}, pod={properties={uid={ignore_above=1024, type=keyword}, name={ignore_above=1024, type=keyword}}}, namespace={ignore_above=1024, type=keyword}, annotations={type=object}, labels={type=object}}}, @timestamp={type=date}, meta={properties={cloud={properties={machine_type={ignore_above=1024, type=keyword}, availability_zone={ignore_above=1024, type=keyword}, instance_id={ignore_above=1024, type=keyword}, instance_name={ignore_above=1024, type=keyword}, project_id={ignore_above=1024, type=keyword}, provider={ignore_above=1024, type=keyword}, region={ignore_above=1024, type=keyword}}}}}, host={properties={os={properties=
wasnt able to copy all because of the post character limit
I exported the template
icingabeat export template
and tried it manually without success
curl -XPUT -H ‘Content-Type: application/json’ ‘http://XX.XX.XX.XX:9200/_template/icingabeat-6.5.4-*’ -d@/etc/icingabeat/elastic.json
I dont know what changed in the new version
Did already solved someone that issue?
Greetings Epytir
