I have some duplicated notifications with notification interval 0, the log looks like:
[2019-12-03 11:50:07 +0100] information/Notification: Sending reminder 'Problem' notification 'server.local!disk!Zugangssysteme-Mail-Service-Notification' for user 'Zugangssysteme'
[2019-12-03 11:50:07 +0100] information/Notification: Completed sending 'Problem' notification 'server.local!disk!Zugangssysteme-Mail-Service-Notification' for checkable 'server.local!disk' and user 'Zugangssysteme' using command 'mail-service-prefdata-notification'.
[2019-12-03 11:50:21 +0100] information/Notification: Sending 'Problem' notification 'server.local!disk!Zugangssysteme-Mail-Service-Notification' for user 'Zugangssysteme'
[2019-12-03 11:50:21 +0100] information/Notification: Completed sending 'Problem' notification 'server.local!disk!Zugangssysteme-Mail-Service-Notification' for checkable 'server.local!disk' and user 'Zugangssysteme' using command 'mail-service-prefdata-notification'.
Has anybody a idea to stop this or is this maybe a bug?
icinga2 - The Icinga 2 network monitoring daemon (version: r2.11.2-1)
So, interval = 0 and times.begin = 900. The logs look a bit like as if the first notification was sent delayed, therefore the reminder word in it. The second notification looks like as if only interval = 0 was configured. Was there a config change followed by a Director deployment in between?
I deleted manually a downtime, that was the reason of the delay. And I activated the notification short time before with a deployment. But 40 minutes later, without any deployments and without delay for sending the notification, I had the same issue:
[2019-12-03 12:24:58 +0100] information/Notification: Sending reminder 'Problem' notification 'master2!disk!Icinga-Admin-Mail-Service-Notification' for user 'icingaadmin'
[2019-12-03 12:24:58 +0100] information/Notification: Completed sending 'Problem' notification 'master2!disk!Icinga-Admin-Mail-Service-Notification' for checkable 'master2!disk' and user 'icingaadmin' using command 'mail-service-prefdata-notification'.
[2019-12-03 12:34:07 +0100] information/Notification: Sending 'Recovery' notification 'master2!disk!Icinga-Admin-Mail-Service-Notification' for user 'icingaadmin'
[2019-12-03 12:34:07 +0100] information/Notification: Completed sending 'Recovery' notification 'master2!disk!Icinga-Admin-Mail-Service-Notification' for checkable 'master2!disk' and user 'icingaadmin' using command 'mail-service-prefdata-notification'.
Object 'master2!disk!Icinga-Admin-Mail-Service-Notification' of type 'Notification':
% declared in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 183:1-183:70
* __name = "master2!disk!Icinga-Admin-Mail-Service-Notification"
* command = "mail-service-prefdata-notification"
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_templates.conf', lines 38:5-38:50
* command_endpoint = ""
* host_name = "master2"
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 183:1-183:70
* interval = 0
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 186:5-186:17
* name = "Icinga-Admin-Mail-Service-Notification"
* package = "_cluster"
* period = "7x24"
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_templates.conf', lines 39:5-39:19
* service_name = "disk"
* source_location
* first_column = 1
* first_line = 183
* last_column = 70
* last_line = 183
* path = "/var/lib/icinga2/api/zones/master/director/notification_apply.conf"
* states = [ "Critical", "OK", "Unknown", "Warning" ]
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 188:5-188:47
* templates = [ "Icinga-Admin-Mail-Service-Notification", "Mail-Service-Perfdata-Notification" ]
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_templates.conf', lines 34:1-34:58
* times
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_templates.conf', lines 35:5-37:5
* begin = 900
* type = "Notification"
* types = [ "Acknowledgement", "Custom", "Problem", "Recovery" ]
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 189:5-189:58
* user_groups = null
* users = [ "icingaadmin" ]
% = modified in '/var/lib/icinga2/api/zones/master/director/notification_apply.conf', lines 190:5-190:26
* vars = null
* zone = "master"
The second thing you’re describing is totally valid. A Problem notification gets delayed by times.begin, with suppressing the initial send and later allowing it once, calling it “reminder”. Your scenario really is a special case not covered by the default log messages.
When a service returns to OK, the Recovery notification is sent.
