Hey Guys,
hope you are all doing well.
I installed Icinga2 → Icingadb → Icingaweb2 → Icingadb-Web and all seems to work fine except the UI, it’s broken. I found the following topic about the same problem: Icingadb-web breaks UI
As in this topic, I also use Icingaweb2 in version 2.10.1, but Icingadb only supports 2.9.x. Can you tell me, if there is a “dirty” workaround to get it up and running or how to downgrade from 2.10.1 to the latest 2.9.x version? I’m not a linux expert yet ![]()
If it is easier to reinstall it with version 2.9.x, can you tell me, how to install the specific version?
- Icinga2 2.13.3-1
- Icingadb 1.0.0-rc2
- Icingaweb2 2.10.1
- PHP 7.4
- Debian 11 Bullseye
- Mariadb 10.5 on a dedicated server
Thanks a lot in advance and best regards
