Hello guys,
do any of you have an idea why are the Doughnut widgets too big?
Any advice have to fix that would be appriciated.
Dashing version - 1.3.7
Ruby 2.7.0p0 (2019-12-25 revision 647ee6f091)
Icinga2 - version: r2.13.1-1
thank you.
Hello guys,
thank you.
Hi Petr,
sorry for not noticing your post here in the community forums.
However, I reacted upon your issue over on GitHub and fixed both, label colors as well as the wrongly scaled round widget types. Just get the latest master from GitHub and take a look at the README.md, you will have to adjust the defined widget types for your doughnut-type widgets.
Hello Daniel,
thank you for fixing the issue. Really appriciate it!
