I am currently testing icinga2 in a dockerized deployment, with traefik and oauth2-proxy for authentication (and backend = external
for the icingaweb config ).
I am using the https://github.com/Icinga/docker-icingaweb2 container.
For the user, icingaweb relies on the the ‘REMOTE_USER’ environment variable to get the username, which i inject from the proxy as X-USERNAME
and adding
SetEnvIf X-USERNAME "(.*)" REMOTE_USER=$0
as apache config to the icingaweb container.
Which seem to work pretty well.
But now i need a way to dynamically add the user groups, is there any way to map an HTTP_Header to groups?
