Divide two metric values with influxdb and grafana and show a single value as result for alerting
HI,
I have not used influxdb queries very often, so consider this question as a newbie question.
I want to divide inBandwidth with outBandwidth from the iftraffic check.
Example Query:
SELECT sum("value") FROM "autogen"."iftraffic64_alias" WHERE ("hostname" =~ /myHost/ AND "service" =~ /Uplink ISP/ AND "metric" =~ /Bandwidth/) AND $timeFilter GROUP BY "metric"
gives:
What i want is something like:
SELECT sum("inBandwidth")/sum("outBandwidth") FROM "autogen"."iftraffic64_alias" WHERE ("hostname" =~ /myHost/ AND "service" =~ /Uplink ISP/ AND "metric" =~ /Bandwidth/) AND $timeFilter
Or in plain dEnglish: I want one number as result for alerting, which shows the ratio from up and download for the last 30 Minutes. I have the two metrics in one series.
Thanks for support.
Rafael
Found it:
SELECT sum(inBandwidth) / sum(outBandwidth) AS Ratio
FROM
SELECT sum(value) as outBandwidth FROM iftraffic64_alias WHERE “metric” = ‘outBandwidth’ AND Time > now() -30m
SELECT sum(value) as inBandwidth FROM iftraffic64_alias WHERE “metric” = ‘inBandwidth’ AND Time > now() -30m
GROUP BY hostname
The same query isn’t working for me. I am on influx 1.7 version
Query -
SELECT sum("400") + sum("200")  AS "successRate" FROM (SELECT sum("value") AS "200" FROM "api.overall.200" WHERE time > now() - 100s),( SELECT sum("value") AS "400" FROM "api.overall.400" WHERE time > now() - 10s)  group by time(60s)
Can anyone suggest what is wrong in this query? It works fine when I use single metric like sum(“200”) + sum(“200”)
Do you get any Error Messages?
sadly I’am not that deep into influxdb, i can’t see whats wrong.
