Questions:
this works in a small scale, we tested 16 kilobyte (which uncompresses to 160 kilobytes)
we need to use ~500 Kilobytes for the content of a variable.
are we running into limits?
is this a bad idea?
I’m in the process of setting up a mirror to have automatic updates without Internet access and total control of the deployment. Besides the security updates, one of the repositories is containing our icinga checks scripts.
This way the machines pull the new versions and it runs over a mature mechanism with all the power of .deb and .rpm like install, uninstall and version pinning etc.
I can’t help you with your questions about internal Icinga2 limitations.
