I installed the latest version (as on the link with the demo). However, in front of each service I have color bars while on the demo link, they are color circles. How to get these circles?
Sincerely,
Flo
Sincerely,
Flo
Do you mean this?
On the version you sent me there are red circles for example. (See screenshot)
And me these are bars (see screenshot)
How to have the circles rather than the bars?
You get the circles in the new Icingaweb2 module that talks to the Redis DB called Icinga DB Web.
The bars are the current monitoring module of Icingaweb2.
Most of us are still on the old module - I for example haven’t yet managed to do the installation in my test Icinga instance.
Ok, thank you for your answer.
I’ll try this way.
I guess that’s it ?
Icinga DB RC2 is a complete rewrite compared to RC1. Because of this, a lot has changed in the Redis and database schema, which is why they have to be deleted and recreated. The configuration file has changed from icingadb.ini
to config.yml
. Instead of the INI format, we are now using YAML and have introduced more configuration options. We have also changed the packages of icingadb-redis
, which is why the Redis CLI commands are now prefixed with icingadb
instead of just icinga
, i.e. the Redis CLI is now accessed via icingadb-redis-cli
Please follow the steps below to upgrade to Icinga DB RC2:
icinga-redis-cli flushall
(note the icinga
prefix as we did not upgrade icingadb-redis
yet) and stop them afterwards.icinga-redis
package where installed as it may conflict with icingadb-redis
.icingadb-redis
) on your primary Icinga 2 nodes to version 6.2.6 or newer.This looks old as it’s now stable and no longer a RC.
https://icinga.com/docs/icinga-db-web/latest/doc/02-Installation/
look on the left for OS specific instructions
