is it possible to disable the ‘badges’ notification individually in the community forum?
I am no fan of achievements and badges and really don’t want to be messaged every time because I have pressed a button or created a new forum entry.
not that I know of, you can only disable “like” notifications inside your profile settings. Maybe they’ll cover badges as well.
Badges are easily obtained in the first weeks being a member, later on you really must be active to achieve all of them. So I don’t think it should be too stressful for you
