Director not talking to background process
Hi All,
Hoping someone might have hit this before, or know where I could dig deeper. The error messages aren’t hugely helpful :frowning:
This is also logged at Github (Icinga Director Background Daemon not reported as running by web interface (but service is running...) · Issue #2963 · Icinga/icingaweb2-module-director · GitHub)
Expected Behaviour:
Icinga Director Daemon page reports connection to background daemon, and as such jobs process etc.
Actual Behaviour
https:///director/daemon page reports:
The Icinga Director Background Daemon is not running. Please check our [documentation](https://<node>/doc/module/director/chapter/Background-Daemon) in case you need step by step instructions showing you how to fix this.
The service does appear to be running however.
[node]# systemctl status icinga-director.service
● icinga-director.service - Icinga Director - Monitoring Configuration
     Loaded: loaded (/etc/systemd/system/icinga-director.service; enabled; preset: disabled)
    Drop-In: /usr/lib/systemd/system/service.d
             └─10-timeout-abort.conf, 50-keep-warm.conf
     Active: active (running) since Tue 2025-03-18 14:10:13 AEDT; 988ms ago
 Invocation: e3149d7b9d3f48a59f3703883e483c90
       Docs: https://icinga.com/docs/director/latest/
   Main PID: 2746990 (icingacli)
     Status: "running, db: no configuration"
      Tasks: 1 (limit: 38421)
     Memory: 11.2M (peak: 11.4M)
        CPU: 46ms
     CGroup: /system.slice/icinga-director.service
             └─2746990 "icinga::director: running, db: no configuration"
Mar 18 14:10:13 node.fqdn systemd[1]: Starting icinga-director.service - Icinga Director - Monitoring Configuration...
Mar 18 14:10:13 node.fqdn systemd[1]: Started icinga-director.service - Icinga Director - Monitoring Configuration.
Mar 18 14:10:13 node.fqdn icingadirector[2746990]: DB configuration is not valid
This is after a full uninstall/reinstall of the icinga-director packages, and clearing out the database and user and recreating it all as we hit a similar problem where the page was not reporting the service running (although, it was).
Other Info
OS: Fedora 41 (Stable) 6.13.4-200.fc41.x86_64 #1 SMP PREEMPT_DYNAMIC Sat Feb 22 16:09:10 UTC 2025 x86_64 GNU/Linux
Icinga installed from ICINGA repos (https://packages.icinga.com/fedora/$releasever/release/)
[node]# dnf list --installed | grep -i icinga
icinga-cube.noarch                          1.3.3-1.fc41                     icinga-stable-release
icinga-cube-web.noarch                      1.3.3-1.fc41                     icinga-stable-release
icinga-director.noarch                      1.11.3-1.fc41                    icinga-stable-release
icinga-director-daemon.noarch               1.11.3-1.fc41                    icinga-stable-release
icinga-director-php.noarch                  1.11.3-1.fc41                    icinga-stable-release
icinga-director-web.noarch                  1.11.3-1.fc41                    icinga-stable-release
icinga-l10n.noarch                          1.3.0-1.fc41                     icinga-stable-release
icinga-php-incubator.noarch                 0.22.0-1.fc41                    icinga-stable-release
icinga-php-library.noarch                   0.14.1-1.fc41                    icinga-stable-release
icinga-php-thirdparty.noarch                0.12.1-1.fc41                    icinga-stable-release
icinga-selinux-common.noarch                1.0.0-1.fc41                     icinga-stable-release
icinga2.x86_64                              2.14.5-1.fc41                    icinga-stable-release
icinga2-bin.x86_64                          2.14.5-1.fc41                    icinga-stable-release
icinga2-common.x86_64                       2.14.5-1.fc41                    icinga-stable-release
icinga2-selinux.x86_64                      2.14.5-1.fc41                    icinga-stable-release
icingacli.noarch                            2.12.2-1.fc41                    icinga-stable-release
icingadb.x86_64                             1.2.1-1.fc41                     icinga-stable-release
icingadb-redis.x86_64                       7.2.7-1.fc41                     icinga-stable-release
icingadb-web.noarch                         1.1.3-1.fc41                     icinga-stable-release
icingaweb2.noarch                           2.12.2-1.fc41                    icinga-stable-release
icingaweb2-common.noarch                    2.12.2-1.fc41                    icinga-stable-release
icingaweb2-selinux.noarch                   2.12.2-1.fc41                    icinga-stable-release
php-icinga.noarch                           2.12.2-1.fc41                    icinga-stable-release
# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.5-1)
Copyright (c) 2012-2025 Icinga GmbH (https://icinga.com/)
System information:
  Platform: Fedora Linux
  Platform version: 41 (Forty One)
  Kernel: Linux
  Kernel version: 6.13.4-200.fc41.x86_64
  Architecture: x86_64
Build information:
  Compiler: GNU 14.2.1
  Build host: unknown
  OpenSSL version: OpenSSL 3.2.4 11 Feb 2025
Application information:
General paths:
  Run directory: /run/icinga2
Old paths (deprecated):
  Installation root: /usr
  Sysconf directory: /etc
  Run directory (base): /run
  Local state directory: /var
Internal paths:
# icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb influxdb2 journald livestatus opentsdb perfdata syslog
Enabled features: api checker icingadb mainlog notification
# icinga2 daemon -C
[2025-03-18 14:21:58 +1100] information/cli: Icinga application loader (version: r2.14.5-1)
[2025-03-18 14:21:58 +1100] information/cli: Loading configuration file(s).
[2025-03-18 14:21:59 +1100] information/ConfigItem: Committing config item(s).
[2025-03-18 14:21:59 +1100] information/ApiListener: My API identity: hum-imas-01.on.act.gov.au
[2025-03-18 14:22:01 +1100] warning/ApplyRule: Apply rule 'ping6' (in /etc/icinga2/conf.d/services.conf: 34:1-34:21) for type 'Service' does not match anywhere!
[2025-03-18 14:22:01 +1100] warning/ApplyRule: Apply rule 'VDSL Sync Speed (C1117)' (in /var/lib/icinga2/api/packages/director/d754c4d8-c6fd-4797-8bdb-61be0edb0029/zones.d/director-global/service_apply.conf: 12:1-12:39) for type 'Service' does not match anywhere!
[2025-03-18 14:22:01 +1100] warning/ApplyRule: Apply rule 'VDSL Sync Speed (C1127)' (in /var/lib/icinga2/api/packages/director/d754c4d8-c6fd-4797-8bdb-61be0edb0029/zones.d/director-global/service_apply.conf: 25:1-25:39) for type 'Service' does not match anywhere!
[2025-03-18 14:22:01 +1100] warning/ApplyRule: Apply rule 'VDSL Sync State (C1117)' (in /var/lib/icinga2/api/packages/director/d754c4d8-c6fd-4797-8bdb-61be0edb0029/zones.d/director-global/service_apply.conf: 38:1-38:39) for type 'Service' does not match anywhere!
[2025-03-18 14:22:01 +1100] warning/ApplyRule: Apply rule 'VDSL Sync State (C1127)' (in /var/lib/icinga2/api/packages/director/d754c4d8-c6fd-4797-8bdb-61be0edb0029/zones.d/director-global/service_apply.conf: 49:1-49:39) for type 'Service' does not match anywhere!
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 4 NotificationCommands.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 50852 Notifications.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 432 HostGroups.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 13734 Hosts.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 Downtime.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 12 Comments.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 IcingaDB.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 FileLogger.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 3 Zones.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 Endpoint.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 2 ApiUsers.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 2 Users.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 ApiListener.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 246 CheckCommands.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 UserGroup.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 3 ServiceGroups.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 3 TimePeriods.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2025-03-18 14:22:01 +1100] information/ConfigItem: Instantiated 13748 Services.
[2025-03-18 14:22:01 +1100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2025-03-18 14:22:01 +1100] information/cli: Finished validating the configuration file(s).
# cat /etc/systemd/system/icinga-director.service
[Unit]
Description=Icinga Director - Monitoring Configuration
Documentation=https://icinga.com/docs/director/latest/
Wants=network.target
[Service]
EnvironmentFile=-/etc/default/icinga-director
EnvironmentFile=-/etc/sysconfig/icinga-director
ExecStart=/usr/bin/icingacli director daemon run
ExecReload=/bin/kill -HUP ${MAINPID}
User=icingadirector
SyslogIdentifier=icingadirector
Type=notify
NotifyAccess=main
WatchdogSec=10
RestartSec=30
Restart=always
[Install]
WantedBy=multi-user.target
# icingacli module list
MODULE         VERSION   STATE     DESCRIPTION
cube           1.3.3     enabled   Cube for Icinga Web
director       1.11.3    enabled   Director - Config tool for Icinga 2
doc            2.12.2    enabled   Documentation module
icingadb       1.1.3     enabled   Icinga DB Web
icingalegacytheme 1.0.0     enabled   This module brings back the icinga theme from icingaweb2 2.9
icingaweb2-theme-solarized 1.0.0     enabled   Solarized Theme
incubator      0.22.0    enabled   Incubator provides bleeding-edge libraries
netbox         4.0.8.1   enabled   Import devices, sites and other objects from Netbox
# cat /etc/icingaweb2/resouces.ini
<snip>...
[director]
type = db
db = mysql
host = localhost
dbname = director
username = directoruser
password = <snip>
charset = utf8
use_ssl = 0
# cat /etc/icingaweb2/modules/director/config.ini
[db]
resource = "director"
Data from /about
Icinga Web 2 Version	2.12.2
Git commit	7f9217b0521f19f770ad59ca17d7d4b3514e54e5
PHP Version	8.3.17
Git commit date	2024-11-13
Loaded Libraries
icinga/icinga-php-library	0.14.1
icinga/icinga-php-thirdparty	0.12.1
Loaded Modules
icingadb		        1.1.3
cube		                1.3.3
director		        1.11.3
doc		                2.12.2
incubator		        0.22.0
netbox		                4.0.8.1
Check if you have any special characters in your .ini file that mess up the syntax.
That seems to have been the issue, @log1c - thank you! I’ll make a note on the github ticket - mayhaps the error message could be improved in someway.
