Is it possible to manage the nrpe.cfg file on number of hosts ( no Icinga2 agent ) in Director?
I assume by “manage” you mean something like “edit and sync”?
No, I don’t think this is possible and I would say the Director should not be used for something like this even if it was possible somehow.
I would suggest something like rsync or a centralized location for the file
