Director import from existing Icinga2/Director
I have to install a new Icinga2/Icingaweb2/Director Master and like to import all hosts/templates/jobs at least everthing from an existin Icinga2/Director master. Is this possinle trough a Director Kickstart configuration or a import source Rest-API/CoreAPI? Or is the correct way to dump and import the whole director database?
Best regards,
Hartmut
Hi Hartmut,
welcome to the community!
Take a look at the configuration baskets: https://icinga.com/docs/director/latest/doc/30-Configuration-Baskets/
This should be exactly what you’re looking for. :slight_smile:
Best regards,
Marcel
I didn’t find the way how to export/import Hosts with baskets? It’s possible to download the hosts to json file, but how to import it on the new master?
Best regards,
Hartmut
