Can someone point me to,or detail the procedure to deploy a new zone with satellite node usingIcinga Director? Should I be running node wizard first or not?
Thanks,
Thanks,
like any other installation, you’ll first need to install Icinga 2 and connect it to the cluster via TLS certificates and configuration (the satellite setup). The node wizard CLI command is what you need to make things easier.
Furthermore, specify the satellite’s endpoint and zone in the zones.conf on your master, and let the Director kickstart wizard import those as external reference. Once that’s done, you can set host objects to that specific cluster zone.
