Hi
I’ve got an HA master setup with 2 master and 1 satellite. the version is (version: r2.11.3-1) on the 3 nodes.
zones.conf in master1
object Endpoint "master1" {
host = NodeName
object Endpoint "master2" {
host = "1.2.3.4"
port = "5665"
object Zone "master" {
endpoints = [ "master1", "master2" ]
object Endpoint "satellite1" {
host = "4.3.2.1"
port = "5665"
object Zone "interne" {
endpoints = [ "satellite" ]
parent = "master"
global = true
global = true
object Zone "global-commands" {
global = true
master2
object Endpoint "master2t" {
object Endpoint "satellite" {
host = "4.3.2.1"
port = "5665"
endpoints = [ "sattelite" ]
parent = "master"
global = true
global = true
satellite
parent = "master"
global = true
global = true
So I try to add an host with icinga director with succes. But after that i try to delete it with succes but he still appear in icingaweb2
I find some config file for it
grep -R host_test /var/lib/icinga2/api/
/var/lib/icinga2/api/zones-stage/interne/director/hosts.conf: display_name = “host_test”
/var/lib/icinga2/api/zones/interne/director/hosts.conf: display_name = “host_test”
and
icinga2 object list --type host --name host_test
Object ‘an-lin-w20-nd.ad.perf1.net’ of type ‘Host’:
% declared in ‘/var/lib/icinga2/api/zones/interne/director/hosts.conf’, lines 1:0-1:39
- __name = “host_test”
- action_url = “”
- address = “192.168.1.20”
% = modified in ‘/var/lib/icinga2/api/zones/interne/director/hosts.conf’, lines 5:5-5:30- address6 = “”
- check_command = “hostalive”
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 2:5-2:31- check_interval = 300
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 5:5-5:23- check_period = “24x7”
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 4:5-4:25- check_timeout = null
- command_endpoint = “”
- display_name = “host_test”
% = modified in ‘/var/lib/icinga2/api/zones/interne/director/hosts.conf’, lines 4:5-4:30- enable_active_checks = true
- enable_event_handler = true
- enable_flapping = true
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 7:5-7:26- enable_notifications = true
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 6:5-6:31- enable_passive_checks = true
- enable_perfdata = true
- event_command = “”
- flapping_threshold = 0
- flapping_threshold_high = 30
- flapping_threshold_low = 25
- groups =
- icon_image = “”
- icon_image_alt = “”
- max_check_attempts = 3
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 3:5-3:28- name = “host_test”
- notes = “”
- notes_url = “”
- package = “_cluster”
- retry_interval = 60
- source_location
- first_column = 0
- first_line = 1
- last_column = 39
* last_line = 1
* path = “/var/lib/icinga2/api/zones/interne/director/hosts.conf”- templates = [ “host_test”, “Linux-generic” ]
% = modified in ‘/var/lib/icinga2/api/zones/interne/director/hosts.conf’, lines 1:0-1:39
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 1:0-1:28- type = “Host”
- vars
* nrpe_timeout_unknown = true
% = modified in ‘/var/lib/icinga2/api/zones/director-global/director/host_templates.conf’, lines 8:5-8:36- volatile = false
- zone = “interne”
I delete config file in
and
and the host gone away from my icingaweb2 so the problem is solve but I don’t understand why i need to rm theses config file, and i don’t want to rm a config file each time because I think it’s not normal
Have you got any idea why ?
