I have a problem with a still exisiting zone in Icingaweb, director. I tried to integrate another satellite to my setup, and everything worked fine, until I wanted to delete the Satellite with it’s endpoint and zone again.
What I tried:
delete the satellite (endpoint and zone) in the api directory:
/var/lib/icinga2/api/...and rerun the kickstart assistant for pulling. The endpoint has been gone since then. The zone still exists in the director and can be choosen in a drop down menu in the hosts config, But cannot be deployed. It’s just showing up. -
reload icinga2
My question, is there any directory or conf. file which still contains the zone?
Or is there any trick to delete this odd zone?
Thank you!
Aaron
