Hey,
I’m using the newest version of Icinga2, IcingaDB, IcingaRedis and Icinga Director.
Now my question:
What is the fastest way to delete all my hosts?
Best regards,
Philipp
Hey,
Now my question:
Best regards,
Philipp
using icinga director api is definitely a fast way to delete all your hosts, but depending on how many are you have, there maybe is a simpler solution
I have around 300 test-hosts. I want to remove them all to test with the import-option around.
use the rest api and call:
GET director/hosts
I would suggest using python, because you will get a json in return.
from this json extract the object_name(s) and iterate over them calling
DELETE director/host?name=%%%%
and replace %%%% with the current hostname of your iteration
if you have the list of hostname present, you can also use a bash script with a for loop
and call for each line:
icingacli director host delete %%%%
I found that in my documentation:
for i in $(icingacli director hosts list);do icingacli director host delete $i;done
Be careful with this command!!!
Perfect!
I think that will help.
I tried that but it also lists the hosttemplates so be careful
