Hello all,
I’ve got a SQL Database connected to Icinga, which is imported via the Director.
In the Database is a column called “deleted_at”.
The column is normally “NULL”.
Is there a possibility to check, if the column is not “NULL” and then automatically delete these Hosts?
- Director version (System - About): 1.8.1
- Icinga Web 2 version and modules (System - About): 2.9.5
- Icinga 2 version (
icinga2 --version
): r2.13.2-1 - Operating System and version: Debian GNU/Linux 11
- Webserver, PHP versions: PHP 7.4.25
