Hey there,
maybe it is a silly question, but I’m a bit confused. I have a master and a satellite behind a firewall and the satellite can connect to the master. The agents and clients, which are in the same network as the satellite, can be monitored through the satellite. But when the WAN is broken the satellite and the agents and clients are OK with delayed check results. I expected them as Down or Unknown. Is it possible to configure delayed as Unknown? Or how do you handle this problem?
