Layers of abstractions by Boost make it in part quite difficult to inspect specific fields inside icinga2 debugging sessions with gdb.
For instance if I hit a breakpoint at lib/icinga/clusterevents.cpp:937, how can I then inspect the hostname of the first endpoint of the zone referred to by origin->FromZone’? In other words: What exact print command would do the job?
0x7fabc000b760 is the first element in a std::set according to the first print statement; 1 is the field index of "name" according to the second print statement)
A single, simpler expression of a kind that could e.g. also serve in conditional breakpoints would still be much appreciated.
