Hi team ,
I am searching for the datatype dictionary inside the datafield in the director
Is there way to add or is it not available for the director?
Please advice Thanks
director does not support dictionaries thru the GUI, only at import (with tricks) or via icingacli.
IF you want to hear the full story why Director will never support dictionaries, you can ask @tgelf
Regards,
Carsten
Thanks for the reply @anon66228339
will be helpful if you could explain this with one example
