Hi everyone,
I have a problem with the data being transfered from the master server to the satellites.
I mean the config files from /var/lib/icinga2/api/zones/…
In the master log i have a warning that the certificate of the satellite is not signed by our CA, but the warning is still there even if i sign it with the command icinga2 ca sign {ticket}
Can this be the cause that the data is not copied ?
Thank you…
