Dashing-icinga2 customized by users
Hello community.
I have deployed a dashing-icinga2 in my icinga2 installation successfully, but a need has arisen, because we have several departments (CAU, CIBER…) and I would like to mount the same dashboard that shows only the resources that correspond to it according to their department and so far, I have only managed to get the dashboard to show all the content of Icinga since it is the same URL for all. Is there a way to deploy a different dashing-icinga2 for each of the departments?
Best regards.
I have managed to get dashing-icinga2 to show only the hosts and services of a particular hostgroup, through the api-rest permissions, with a filter applied inside the icinga api-user.conf file.
I just need to know if it is possible to deploy more than one dashing-icinga2 dashboard pointing to the same installation.
I currently have one mounted, the one that is mounted by default in the dashboard installation.
http://localhost:8005/icinga2
Would it be possible to create several?
http://localhost:8005/dashboard1
http://localhost:8005/dashboard2
http://localhost:8005/dashboard3
Each one with its own api-user and filter.
I don’t know if this is possible.
Could you maybe show the same dashboard for all users but use different filters in shared navigation for module “monitoring”?
Restrictions for user CAU:
monitoring/​filter/​objects: servicegroup_name=CAUservices|hostgroup_name=CAUhosts
monitoring/​blacklist/​properties:
Restrictions for user CIBER:
monitoring/​filter/​objects: servicegroup_name=CIBERservices|hostgroup_name=CIBERhosts
Alternatively you could look at the icinga modules customdashboards and teamdashboards from this source: https://github.com/RISE-GmbH
Thank you very much for your reply.
The first suggestion doesn’t work for me, because my boss doesn’t want the staff of one department to see the monitored items of a department other than their own.
But the modules customdashboard and teamdashboard could be very helpful for me.
Again thanks for your interest and help and I will inform you if with these indications I could solve this question.
Best regards.
