I have setup dashing according to the docs (apart from not running bundle as roo…t, because it only works as root) and get only some sample values.
API user has the correct permission (even tried with "*").
The VERY strange thing: As soon as I do `systemctl stop dashing-icinga2` or `systemctl restart dashing-icinga2` the values are updated to the actual numbers.
looking at the log file of the dashing thin server also shows that data is pulled:
zones {"zone1"=>{"client_log_lag"=>0.0, "connected"=>true, "endpoints"=>["SRVzone1MONSAT"], "parent_zone"=>"master"}, "zone2"=>{"client_log_lag"=>0.0, "connected"=>true, "endpoints"=>["srvzone2monsat"], "parent_zone"=>"master"}, "master"=>{"client_log_lag"=>0.0, "connected"=>true, "endpoints"=>["srvzonemastermonmaster"], "parent_zone"=>""}, "zone3"=>{"client_log_lag"=>0.0, "connected"=>true, "endpoints"=>["SRVzone3MONSAT"], "parent_zone"=>"master"}}
checker {"idle"=>150.0, "pending"=>0.0}
command 1.0
main-log 1.0
graphite {"connected"=>true, "work_queue_item_rate"=>2.466666666666667, "work_queue_items"=>0.0}
app {"enable_event_handlers"=>true, "enable_flapping"=>true, "enable_host_checks"=>true, "enable_notifications"=>false, "enable_perfdata"=>true, "enable_service_checks"=>true, "environment"=>"", "node_name"=>"srvzonemastermonmaster", "pid"=>26523.0, "program_start"=>1601457142.66971, "version"=>"r2.12.0-1"}
ido-mysql {"connected"=>true, "instance_name"=>"default", "query_queue_item_rate"=>7.416666666666667, "query_queue_items"=>0.0, "version"=>"1.14.3"}
notification 1.0
Stats: [{"label"=>"Host checks/min", "value"=>30.0}, {"label"=>"Service checks/min", "value"=>112.0}, {"label"=>"json_rpc queue rate", "value"=>"8.22"}, {"label"=>"graphite queue rate", "value"=>"2.47"}, {"label"=>"ido-mysql queue rate", "value"=>"7.42"}]
Severity: [{"label"=>"srvzone3aap - cpu", "color"=>"yellow", "state"=>1}, {"label"=>"srvzone2temp19 - services", "color"=>"purple", "state"=>3}, {"label"=>"zone2Fax - disk-c", "color"=>"purple", "state"=>3}, {"label"=>"srvzone2temp19 - swap", "color"=>"purple", "state"=>3}, {"label"=>"srvzone2temp19 - memory", "color"=>"purple", "state"=>3}, {"label"=>"srvsql - services", "color"=>"purple", "state"=>3}, {"label"=>"srvzonemasterdocuware1 - memory", "color"=>"purple", "state"=>3}, {"label"=>"srvzone1hv2 - services", "color"=>"purple", "state"=>3}, {"label"=>"zone2SW-A04 - memory", "color"=>"purple", "state"=>3}, {"label"=>"zone2File - disk-d", "color"=>"purple", "state"=>3}, {"label"=>"srvzone1opc - swap", "color"=>"purple", "state"=>3}, {"label"=>"srvzone2usv1 - hardware-health", "color"=>"purple", "state"=>3}, {"label"=>"srvzonemasteropc - disk-c", "color"=>"purple", "state"=>3}, {"label"=>"cisco1 - hardware-health", "color"=>"purple", "state"=>3}, {"label"=>"srvzonemastersql - swap", "color"=>"purple", "state"=>3}, {"label"=>"zone2Spl - swap", "color"=>"purple", "state"=>3}, {"label"=>"srvzone1opc - memory", "color"=>"purple", "state"=>3}, {"label"=>"srvzonemastersql - memory", "color"=>"purple", "state"=>3}, {"label"=>"zone2SW-A04 - cpu", "color"=>"purple", "state"=>3}, {"label"=>"zone2DB - disk-d", "color"=>"purple", "state"=>3}]
Doesn't matter if I use v.2.0.0 or v3.0.0
Strange thing, bc only this server is affected.
A different server of a different customer (running onprem instead of azure) works without problems.
versions:
icinga2 is on r2.12.0-1
OS is Ubuntu 18.04.5 running in Azure
tested with FF & new EDGE
I implemented a dirty workaround restartung the dashing every morning, but that doesn't help.
If you open the dashboard after the restart (new tab, new browser) only the sampel (or what ever) data is displayed.
