As our teams are no longer in fixed offices, I would like to define a teams dashboard maybe on my user of the dashboard user and then inject it into the dashboards of the members of this team.
You could also take a look here and maybe test it if it suits your needs. Though, while it looks abandoned it is still something we’d like to finish, so your feedback is valuable!
If you have trouble testing it, we’d also assist! (Here, or there)
I had a quick look without installing and I haven’t seen a way to define a team dashboard and map it to a Icingaweb2 role.
It was to much code and I didn’t see any documentation in the pull request to answer this question.
Is there a way to define a dashboard and attach it to all members of a role?
Is it possible to attach N dashboards per role or can a user get N dashboards from N roles?
