I need to make dashboard in icingaweb2 which shows only hosts in problem condition for some period (2 hours for example). So I hope to make a function, which will return True for such a host and I will filter it out in icingaweb2 filters.
But I am not able to make the first step. Let’s start with the simplest function:
template Host “mygeneric-host” {
vars.state_overdue = {{ return “Test” }}
It seems work, but the vars.state_overdue has no “Test” value, it has Object of type ‘Function’ value in icingaweb2
icinga2 object list --type Host --name mytest
- vars
- state_overdue
% = modified in ‘/etc/icinga2/zones.d/global-templates/templates.conf’, lines 33:4-33:44- arguments =
- deprecated = false
- name = “”
- side_effect_free = false
- type = “Function”
- state_overdue
I am missing probably some very basic info how to call the function, but I am not able to figure it out.
Thank you
