I picked up this nagios java bases sftp check. The java portion is installed, and works fine I can manually run the check and get a nagios formatted output, which as I understands should work with icinga2.
Example of the command
java -jar /usr/lib/nagios/libexec/check_sftp.jar -port=22 -t=10 -temp=/tmp/ -host=x.x.x.x -user=‘xxxxx’ -pwd=‘xxxxxxxxx’ -warning=1000 -critical=2000
Example of output
OK: transfer time to 10.128.0.12 is 0.34s|time=0.34s;1.0;2.0;;
The problem comes up when I try to create a custom check command
the snippit I added in the command.conf is
object CheckCommand “check_sftp” {
// import “plugin-check-command”
command = {"java -jar /usr/lib/nagios/libexec/check_sftp.jar -port=22 -t=10 -temp=/tmp/ -host=x.x.x.x-user=xxx-pwd=xxxxxxxx-warning=1000 -cri$
arguments = {}
When I run icinga2 daemon -C . You guessed it big error.
root@icinga-mon:/etc/icinga2/conf.d# icinga2 daemon -C
[2021-04-14 14:49:30 +0000] information/cli: Icinga application loader (version: r2.10.3-1)
[2021-04-14 14:49:30 +0000] information/cli: Loading configuration file(s).
[2021-04-14 14:49:30 +0000] critical/config: Error: Value computed is not used.
Location: in /etc/icinga2/conf.d/commands.conf: 196:14-196:167
/etc/icinga2/conf.d/commands.conf(194): object CheckCommand “check_sftp” {
/etc/icinga2/conf.d/commands.conf(195): // import “plugin-check-command”
/etc/icinga2/conf.d/commands.conf(196): command = {“java -jar /usr/lib/nagios/libexec/check_sftp.jar -port=22 -t=10 -temp=/tmp/ -host=x.x.x.x -user=xxxx-pwd=xxxxxxxxx -warning=1000 -critical=2000”}
/etc/icinga2/conf.d/commands.conf(197): arguments = {}
/etc/icinga2/conf.d/commands.conf(198): }
So can someone please point me in the right direction. I know I am doing it wrong, I am however a newby to Icinga2, and tried my best here.
