Morning.
I’m having a bit of trouble moving my code into the ‘library’ folder in my custom module. I have the following layout:
Inside /usr/share/icingaweb2/modules/statusblocks:
- application
- clicommands
- controllers
- HelloController.php
- forms
- locale
- views
- doc
- library
- StatusBlocks
- File.php
My library class looks like this:
/usr/share/icingaweb2/modules/statusblocks/library/StatusBlocks/File.php:
<?php
namespace Icinga\Module\StatusBlocks;
use DirectoryIterator;
class File
public static function listFiles($path)
$result = array();
foreach (new DirectoryIterator($path) as $file) {
if ($file->isDot()) continue;
$result[] = (object) array(
'name' => $file->getFilename(),
'path' => $file->getPath(),
'size' => $file->getSize(),
'type' => $file->getType()
return $result;
And my controller looks like this:
/usr/share/icingaweb2/modules/statusblocks/application/controllers/HelloController.php:
<?php
namespace Icinga\Module\StatusBlocks\Controllers;
use Icinga\Web\Controller;
use Icinga\Module\StatusBlocks\File;
class HelloController extends Controller
public function worldAction()
$this->view->files = Hello::listFiles($this->Module()->getBaseDir());
var_dump($this->view->files);
die();
I get the following error:
Uncaught Error: Class 'Icinga\Module\StatusBlocks\Blocks\File' not found in /usr/share/icingaweb2/modules/statusblocks/application/controllers/HelloController.php:10
If I manually include the file in the controller like this:
include_once "/usr/share/icingaweb2/modules/statusblocks/library/StatusBlocks/File.php";
… it works fine. But I’m pretty sure I shouldn’t have to do that - I was under the impression the /library/ folder was all included/autoloaded?
Can anyone suggest what I might have done wrong?
Thank you so much!!!
Geoff
