Installed Cube module Version 1.1.0.
Custom fields created and assigned to the template and that is populated to the hosts successfully.
But nothing happens when I click on add dimension under Cube > Hosts.
Could someone please help.
Developer console has logged errors?
No error is console its just that no data fields are populated when i click on add dimension option.
I have a similar issue, apologies if this is a duplicate: https://community.icinga.com/t/icinga-cube-module-data-fields-do-not-show-up-or-take-a-long-time-to-do-so
