Hi !
I need to create dependencies for service checks.
I had some service templates and host templates.
I want to create dependencies to keep low the amount of notification in case of problems.
How can be achieve this with Director ?
REgards
P.
depending on which version you are using. But since v1.7.0 you can find a a function “Dependencies”
But be aware that there exists an open issue if you can to create a service to service dependency: https://github.com/Icinga/icingaweb2-module-director/issues/1142. It’s on the roadmap for 1.8.
THX… But is not clear how these dependencies are related to Host template and/or Service template…
Is there documantation about this ?
Is not crear how can use this feature (dependencies) to achieve my goal.
I need something that block check and notificatios (or at least notification) to child checks.
Ones I have defined a root check… and other dependencies checks
THX
The director is rendering a icinga2 configuration like described here https://icinga.com/docs/icinga2/latest/doc/09-object-types/#objecttype-dependency. How it is working with icinga is decribed here: https://icinga.com/docs/icinga2/latest/doc/03-monitoring-basics/#dependencies. With that informations from the docs you can do what your goal is. If you don’t want to get a notification if the parent host is down. You have to activate the corresponding option - in the form from the director: “Disable Notificiations” (see my screenshot).
@stevie-sy i have a couple of questions can you please tell me your email or telegram? I have having same problem. Please help me out my email is wajiibklyn@aol.com.
