Hello
I want to start with a simple master / agent setup and then go on from there. I have used the node wizard on master and agent and then configured the services according to the official documentation. The agent host is not shown in icinga2web and I dont get any feedback about it’s disk. Why does this not work? I followed the documentation to the letter and icinga2 daemon -C is both green on agent and master.
On Master: /etc/icinga2/zones.conf
* on 2024-06-05 15:03:19 +0200
object Endpoint "icinga2.unknown.de" {
host = "10.10.10.7"
port = "5665"
object Zone "master" {
endpoints = [ "icinga2.unknown.de" ]
object Endpoint "icinga-test1.unknown.de" {
object Zone "icinga-test1.unknown.de" {
endpoints = [ "icinga-test1.unknown.de" ]
parent = "master"
global = true
global = true```
On the agent: /etc/icinga2/zones.conf
host = "10.10.10.7"
port = "5665"
parent = "master"
global = true
global = true
And this is on the Master again in /etc/icinga2/zones.d/master/services.conf
apply Service "disk" {
check_command = "disk"
// Specify the remote agent as command execution endpoint, fetch the host custom variable
command_endpoint = host.vars.agent_endpoint
// Only assign where a host is marked as agent endpoint
assign where host.vars.agent_endpoint
