Good evening Colleagues,
a question about creating users through the Director API.
I need to create a user to link notifications to. I didn’t find the user section in Director Basket or in the Director API description.
It is assumed that I create users through the Icinga API and then import them into Director, or did I miss something?
The Endpoint you are looking for is under:
https://icinga.example.com/icingaweb2/director/users
thank you )))
it simple
