Create negated host check within Director
I tried to create a negated hostalive check by wrapping the hostalive check with the negate check.
First added the needed custom vars ($negate_command,$negate_arguments,…), created a new command with import of “negate” command and applying the command to host via host template.
If I understood the wrapping from negate (default config from plugin), it should take the values from $negate_command and $negate_arguments and append them after the common options.
The executed command should look like this
‘/path/negate’ ‘-o’ ‘WARNING’ ‘/path/check_ping’ ‘-H’ ‘x.x.x.x’ ‘-w’ ‘a,b’ ‘-c’ ‘b,c’
where
$negate_command=’/path/check_ping’
$negate_arguments=’-H’ ‘x.x.x.x’ ‘-w’ ‘a,b’ ‘-c’ ‘b,c’
After deploying the check, icinga2 was not able to expand the variables.
I’ve already tried several variable types (string, array) and syntax ( with ", comma separated, …),
but nothing works.
Any ideas?
BR
Manfred
icinga2 2.10.4
director (only reports version master, files from Nov 18)
php 7.2
Hi Manfred,
did you solve that issue? I assume, you did?
Regards,
Henning
