Having provided a password in /etc/icingadb-redis/icingadb-redis.conf and removed the # along with adding the password to /etc/icingadb/config.yml the following log entries appear.
This is after running sudo systemctl restart icingadb-redis icinga2 icingadb
Is there another location where the icingadb-redis password must be provided?
tail -f -n 2 /var/log/icinga2/icinga2.log
[2024-07-05 15:03:52 +0100] information/IcingaDB: Trying to connect to Redis server (async) on host '127.0.0.1:6380'
[2024-07-05 15:03:52 +0100] critical/IcingaDB: Cannot connect to 127.0.0.1:6380: NOAUTH Authentication required.
icinga2 feature list
Disabled features: command compatlog debuglog elasticsearch gelf graphite influxdb influxdb2 journald livestatus opentsdb perfdata syslog
Enabled features: api checker icingadb mainlog notification
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.2-1)
System information:
Platform: Fedora Linux
Platform version: 40 (Cloud Edition)
Kernel: Linux
Kernel version: 6.9.7-200.fc40.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 14.0.1
Build host: unknown
OpenSSL version: OpenSSL 3.2.1 30 Jan 2024
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
icinga2 daemon -C
[2024-07-05 14:51:57 +0100] information/cli: Icinga application loader (version: r2.14.2-1)
[2024-07-05 14:51:57 +0100] information/cli: Loading configuration file(s).
[2024-07-05 14:51:57 +0100] information/ConfigItem: Committing config item(s).
[2024-07-05 14:51:57 +0100] information/ApiListener: My API identity: heimdall.railriverroad.co.uk
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 2 NotificationCommands.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 12 Notifications.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 2 HostGroups.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 Host.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 Downtime.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 IcingaDB.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 3 Zones.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 User.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 Endpoint.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 246 CheckCommands.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 UserGroup.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 3 ServiceGroups.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 3 TimePeriods.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2024-07-05 14:51:57 +0100] information/ConfigItem: Instantiated 11 Services.
[2024-07-05 14:51:57 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2024-07-05 14:51:57 +0100] information/cli: Finished validating the configuration file(s).
